07NAHWKI
So this is question regarding my mothers legacy, we recently just replaced the timing belt, and spark plugs. After we replaced the timing belt, the car developed a misfire in cylinder 4, we then proceed to replace the wires hoping that was the culprit. But it didn't change anything. My father thinks that the timing is off by 1 tooth and that is causing the misfire. So we are wondering if the timing being off by 1 tooth could cause a misfire in cylinder 4, or should we start looking at other possible causes.
Thanks,
Thanks,
