I have a set of yoko's A035, And I'm curious how much PSI I should fill them with...
Oct 14, 2005 #2 ReZDoG I'm not ReZPunk I have a set of yoko's A035, And I'm curious how much PSI I should fill them with...
Oct 15, 2005 #3 M Mr Mike New member summer you can run 27 ish to 33ish... give or take to taste, winter you want to air down for a bit of extra traction, but bewear the debead.
Oct 15, 2005 #5 ReZPunK New member they are all at 45 right now...i felt 50 was too much i will drop them back to 35 or 40 if you want.
Oct 18, 2005 #6 L LastDitchRacing Member Run them someplace around 30-33psi. A few psi difference front to back if you want. They are NOT winter tires-do not try them in the snow! Cheers! John
Oct 18, 2005 #7 ReZPunK New member will do thanks a bunch! they are a tight fit on the saturn...might have to trim back the fenders LOL
Oct 22, 2005 #9 ReZPunK New member problem sovled. we just took the 14" Michelin M4's off the Lemans heheh
