TheSoundMan
Ok, so i have recently noticed that I no longer buil full boost in any gear. I used to peak out at about .09 MpA, now I never get better than .06, and that's pushing it. I noticed this after taking the IC off to change the starter, but that's not to say It wasn't happening before that, just didnt notice. I thought it might be a loose hose clamp, but took the IC off again, and double checked it, all good. Any other likely culprits to check? what else could be causing this and how do I go about finding the problem? any suggestions?
Thanks
Thanks
