so in the near future im most likely getting a dp, i have heard rumors that you can put a resistor? or some such on a cattless and get away with it for inspection i dont wanna have to swap it for the inspection every time. i was looking into invidia divorced
What you're talking about is a resistor to trick the rear O2 sensor. The alternative is to just have the associated CELs turned off with a reflash.That would be a resonator. Most of the shops around here are not going to check anyways. I wouldnt worry about it. Unless you live in cumberland county.
my bad I forgot about those resistors/cel fixWhat you're talking about is a resistor to trick the rear O2 sensor. The alternative is to just have the associated CELs turned off with a reflash.
