Problem: under acceleration it hesitates and almost dies. can't get it over 30 or so MPH
Car: 1987 1.8L Subaru GL 47K miles
Things done so far
Fuel filter
wires
coil
plugs
cap
rotor
fuel pump is running (no way to test output if its enough)
injector sprays (TBI)
cleaned throttle plate
vacuume checks good -20psi
no check engine light
no fault codes on the "ECU"
scratching my head on this one.
suggestions??
Things done so far
Fuel filter
wires
coil
plugs
cap
rotor
suggestions??
