RallyGuy24
I am looking for some info. I'll start from the beginning and go from there.
At the end of May, I installed a new flywheel, clutch, throwout bearing, and changed the tranny fluid to Royal Purple GL-4 and GL-5 rated 70-90.
Here's the symptoms - When driving the car on the highway, once the tranny warms up, when I let off the accelerator, I hear a god awful grinding noise. It goes away when I am on the accelerator, but as soon as I let off its bad. I thought that this was due to the throwout bearing clip falling off and allowing the bearing to ride slightly against the fingers of the pressure plate. that's what it sounds like, and I thought this because the design of the clip wasn't that good. Now that I have the tranny on the ground, I see the throwout bearing is functioning just as it should. Now I am wondering if 5th gear is junk, or if I have a bearing in the back of the tranny that's gone. I don't remember if it made this noise in any other gear. Another note, I didn't drain the fluid as I dropped the tranny, and when I got the tranny leaning back a bit, fluid drained out the rear seals. Should fluid be able to drain out of there?? I don't think so, but I am not sure seeing it might let fluid by to lubricate the driveshaft. So I guess my question is, Do i need to have the tranny rebuilt, or what does this sound like?
