Pedro
٩(͡๏̯͡๏)۶
well we could just get the welder out and fix that case problem. I would like to see a blown up trans though. and I would have to send out a piece of the case to get the alloy makeup.
i've also heard that the case on the 5spd is the weak link, its prone to flexing under load, which sends the gears into contact at obscure angles and the load is distributed on the gear surface incorrectly. the 6spd apparently has a different case design, and hence is less prone to breaking gears for that reason.
some people say that the RA gears are a bandaid fix for that reason, they just replace the breaking gears with stronger ones, as opposed to fixing the problem at the root.
its like giving someone with childhood issues anti-depressant meds, it doesn't really fix the problem at the source.
