2002 RS/ 02-02 wrx parts
SubaruGeek
hi guys,
Im looking to sell my 02 impreza RS and my 02-03 wrx parts. I have had things come up and i would like to see these parts go to a good owner and the car to a good owner. Below is the list of parts and what has been done to the car.
2002 Impreza RS: 187,??? miles.
New Head Gaskets
New valve cover gaskets
New intake gaskets
New cam seals
New spark plugs
New plug wires
New timing belt
New timing tenstioner
New All timing idler pullies (3 or 4 or them)
New clutch
New pressure plate
New flywheel
New throttle bearing
New throttle bearing clips (Holds it in place)
New A/C idle pulley
New A/C drive belt
New Power steering drive belt
New air filter
New Snow tires (all 4 are new with 4356 miles on them)
New thermostat
New Thermostat gasket
All the fluids were drained and replace with new syntatic fluids
New Front links
Kartboy short-shifter
Momo shift nob
new brakes around 7,000 miles ago
Rotors were turned
New Radio
The body is in very good shape. little rust on the drivers rear (not very much, about as big as a fifty-cent coin. The car has a white trunk and sti wing. The orginal was starting to leak from the wing bolts. The car is in very very clean shape. Has a new sti carpet inside of it. No tears in the interior, has both carpet and all weather floor mats. When sold I will fill the gas tank and the car will be cleaned. Im asking 7000.
New wrx parts:
02-05 Cold-Air intake (New)
02-03 Fornt mount intercooler & piping(New)
Light weight Crank pulley (New)
02-06 Front and rear Kartboy links (New)
Spt oil cap (New)
Spt lowering springs (02-04 wrx/Rs) (New)
02-05 Wrx motor: (Used) The motor spun a rod bearing. The crank may still be good not sure havnt really broke into it yet. It is missing a piston and the timing belt. Other wise perfect for rebuilding a motor while not having to have ur car in the garage.
Asking 1,000.00 for everything, Willing to sell seprate if i get a lot of people asking, but would like to sell as a whole. I will be posting pictures of the parts and car later. Need to download them. Plz send me a mail if ur interested. Please no trying to bargain me dry I wont allow it. Im asking for exactly a little under what i paid for everything.
Hey mate, I might be willing to by the light weight crank pulley and the lowering springs! Let me know if u wanna sell separate! I don't need all that other jazz.
the motor is complete heads,intake,injectors,throttle body so there isn't much that it is missing
god my engine knowledge is so limited. would the heads have been spared from damage? or is that not known till its taken apart. i'd be interested if the heads are likely ok.
The heads are fine. There should be no issues with anything on the motor but maybe the crank. A spun bearing dosn't really cause any damage but maybe to the rod and the crank. But even then depending on how soon the car was parked it may have not even cuased any damage.
alright, i'd be interested in the complete motor if you were to separate. shoot me a pm if you wanna talk details.
here are some prices on the items. Im willing to sell seperate b/c i have enough people looking.
Cold-air: 50.00
Front mount intercooler and piping: 125.00
Pulley: 100.00
Motor: 600.00
other stuff has sold.
Springs: 200.00
