car sputters on acceleration.....until warm?
Legwagon
BC-BF-*BJ*
as stated:
when I press on the gas pedal when cold the car starts to sputter....rpm guage goes a bit haywire until warm......when warm nothing of the sort happens?? what is this all about?
also maybe a crank sensor...if the tach is going haywire.
:dontknow: need more info.
year?
Model?
engine?
last tune-up?
mods?
timing belt?
yea subarudes right
1992
legacy
wagon
2.2
210,0xx mi.
no mods.
timing belt was replaced on 12/29/2006 got the slip for it. around that same time the water pump was replaced as well...
crank sensor???
more explain.
The crank sensor sends a signal to the omputer to let it knw where it is on timing. Tach. But usually if its bad it wont start at all, or they start going bad after its hot....like you'll be driving, stop at the store, come back out and it wont start for 30 minutes, then it will start.
So now we're back to MAF, Coolant temp, or ignition (plugs, wires, coil)
