What year OBS?has anyone put forester struts in an obs ? i want to lift my car but would rather do bigger struts then a block/spacer lift . or could i just use forester springs?
how bout the xt struts ? are those wayyy to different to put in ?Ok yeah you will be able to bolt up first gen Forester struts, may have to swap the rear strut tops, and most likely use Forester rear trailing arms too
Depends on what you're going to do with them. AGX's are adjustable, GR2s not. You might want to do autocross and stiffen them up, then soften them to drive daily. If you're going to just daily the car and maybe do some spirited driving, GR's should be fine.are kyb agx's worth the double price over the gr-2's?
pretty much hit the nail on the head with that....Depends on what you're going to do with them. AGX's are adjustable, GR2s not. You might want to do autocross and stiffen them up, then soften them to drive daily. If you're going to just daily the car and maybe do some spirited driving, GR's should be fine.
Team O'Neil runs GR2's on their school cars. GR2's are meant to be replacement units for stockers, but word is they're a little bit stiffer than stock.
IMO, no; just get GR2's. (note, I am also very cheap)
Others may way in with different opinions.
