Help xpt stage 2 tune
wrx_impreza_04
I have xpt stage 2 tune in my ecu and was wondering if i change just the turbo back exhuast back to stock would that do anything bad to my car?
You can not remove the down pipe. You can change the cat back but not the full turbo back
First of all.... welcome back steve_wrx.
You might try just starting with giving Seph his STI trunk lid back......
You think you're smart huh? You forget that I see all of your registering info including your IP addresses.......
o dude i kno seph is a good guy but when we traded he should of looked it over better instead of trading and wanting it back its like me buying a xbox 360 off a guy and i asked does it work and he says yeah and i give him the money and i turn it on and it dont work i would look at it first then buy it
this just confirms that you would trade something that you knew was no good to an unexspecting person which is pretty lame in my book
i'm sure if you maned up to the fact that you wronged this person and trade back, you could get some help with your tune
so if you bought an xbox off someone and you got it, it worked like crap.. you are saying that you would not ask for your money back?
Man up and return it because you obviously knew your trunk was junk and hid that from him and admit that you are screwing him over. Be a decent guy and people can forgive you and move on. If not, then no one will forgive you and no one will forget and NO ONE will help you.
What was wrong with it? Did you present it in a way that it appeared to be OK and it obviously wasn't?
If it was no big deal or "he should have checked it out" then why the name change?
yes it will. first of all it will make u loose 125whp but most inportantly you can never put on a flux cappasitor on if you have a stock exhaust wich will keep you from being able to acheive time travel so think it over
