you can do that, and you can also get accesstuner race which is free and modify the 1st gear boost multiplier table to = 0. this may solve the problem too.
First I would check the vacuum lines from the compressor nipple, and wastegate nipple to the ebcs to make sure none are cracked etc
but if you reflash the lwg map, and you still get a spike, probably not a tune issue, probably mechanical.
