Legacy22GT
Right, so i've been tearing apart my 1999 legacy gt looking for the source of my electrical problems.
symptoms:
horn doesn't work
Airbag light is on
ABS light is on.
I checked all the fuses, both in the car and engine compartment.
They're all fine.
I reseated the fuses.
Took apart the radio cluster area, unplugged and reseated the airbag module plug.
took apart the underside of the dash, verified that all the plugs are fine.
Has anyone had similar problems?
did a little searching and it might be a "clockspring" for the horn and airbag.
the abs light might be from a sensor, but I'm not sure on how to check it without replacing them, which it might not even be the problem.
anyone got any suggestions?
symptoms:
horn doesn't work
Airbag light is on
ABS light is on.
They're all fine.
