Just put in a decent amount of work on my car a few weeks back and now I have a vibration that won't go away. I had Rick (flat4awd) go for a ride and he said he could barely notice it but it bugs the heck out of me! Just asking for your input, any info/advice will help. Taking a road trip to Caribou to see my father at the beginning of August and I don't want to be shaking the whole way. Thanks!
99 Impreza OBS
Sti pink struts with cut springs (will be replacing the springs soon, bought them with cut springs)
04 Wrx wheels (balanced out fine)
03 Wrx 5 speed transmission
r160 from the same 03 Wrx
Running my original obs driveshaft
New:
Tires
Exedy clutch kit
Lightweight flywheel
Clutch master and slave cylinders
Rear main seal
Resealed the oil/air separator plate
The vibration doesn't start until 45mph and is still there up until 90 ( I wont drive faster than that)
I tried shutting the engine off going down the road, tried rolling in gear with the engine off and clutch in, etc all with no change. tried rotating my tires from front to rear and there's no change.
Possible causes (I think)
Bad wheel bearing
Warped or bad CV shaft
Need a wrx driveshaft to go with the trans and rear diff
Bad top hat
Cut springs causing vibration
Control arm bushing?
driveshaft center bearing gone bad?
Sway bar links? I don't think this would cause a vibration though.
99 Impreza OBS
New:
Tires
Exedy clutch kit
Rear main seal
Bad wheel bearing
Bad top hat
