Maybe I can clarify a bit. I want the STOM folks to be well informed!
Anti-lag(or bang-bang as some Euros call it), is a means to keep the turbo spinning when you're off throttle, reducing lag when you're back on it.
This means that the power is always there(hopefully) when you need it.
Anti-Lag is programmed using a standalone ECU. When off throttle with the anti-lag enabled, the car basically dumps fuel into the engine while changing the cylinder firing. Unburnt fuel ends up int he exhaust manifold, where the heat causes it to ignite, causing the turbo to spool.
Anti-lag can be programmed to be agressive or mild, depending on preference. If it's too aggressive, the car will pull even when you're off throttle. This can be a bad thing in slippery conditions.
Usually, we attempt to to get 0 psi of vaccuum/boost at idle with the anti-lag enabled.
Some of the WRC cars see wicked boost at idle.
Anti-lag isn't used when off stage. It makes the car difficult to drive slowly around town.
If the tune and the anti-lag are done correctly, and you use quality oil, turbos shouldn't burn out too often. Those that are running on the ragged edge will always see a higher failure rate than those that don't. We ran 25psi with anti-lag and had no turbo failures over an entire season.
In terms of Cats, antilag isn't too friendly to them due to the rich mixture. Our cat is all the way at the end of the exhaust. We've found they simply disintegrate after awhile.
Cheers! Joh
