Blower motor
HR radness
His royal radness
So the blower quit working on the unstoppable wagon of doom. I researched a bit and it looks like it's either the blower motor resistor, relay, or the blower motor itself. Anyone have this happen before?
Rightseat
get thee to a junqueyard
scavenge all 3 parts you mentioned at once
replace em 1 by one, whatever is easiest 1st
when the blower suddenly works, that means you have fixed it
DG
Scooby Mensa Society
R
rallyXcramps
Guest
reason # 442 to have a volt/ohms meter or multimeter (aka DVOM <--->digital volt ohms meter).
You could see if there was power at the blower. If you had a voltmeter or test light.
If there is then you know everything else is good and the blower is bad. Usually if the resistor burns up you'll still have high. To figure out if the relay is bad swap it with another relay in the fuse box and see if der blower comes on. Theres a quick and easy way to test fuses without plucking them all out...if you had a test light.
When is your b-day? I'm gonna get you a test light and DVOM for your b-day. ;D
A REAL man's beater doesn't need a blower or heat. ;D j/k man!
HR radness
His royal radness
So let me get this straight....................
I need a voltmeter?
Is that what you are trying to tell me?
hmmmmmmm
I will visit radio shack today., all knowing all seeing one
