Clutch going?
-=Lobstah=-
So i think the clutch on my 96' Brighton is on its way out. Not sure, but i guess so.
The pedal is wicked soft, barely any resistance. Should i try and bleed it? How's that done?
2 Shorty: How much does Evergreen charge to change a clutch?Ball park price.
EDIT: Nevermind the bleeding
it's cable
they're not that diff. to do on that car a pair of ramps and a floor jack and it could be done in a couple hours
i'd try taking the slack up in the cable first
yeah, if it ain't slippin', it's probably a linkage issue. On the 2.2L, the clutch design has been changed. If you use factory parts, you must replace the flywheel/disc/pressure plate as a set.
