drvsdwz
DRiVe SiDeWayZ
So I've been looking at the Grimmspeed thermostat. $45 at Rally sport direct doesn't seem like a bad deal.
http://www.rallysportdirect.com/GrimmSpeed-160-Degree-Thermostat-Most-Subaru-Models
I'm looking at pros and cons for using this.
Pro's
Con's
Basically, I want to know if this will have any adverse effects on the engine and other systems the cooling systems supports. If the engine parts were designed to operate at 185, what will an operating temp of 160 do?
This is open for discussion, but please be relevant to topic with opinions and experience.
Thank you!
Pro's
- Offers better cooling efficiency as it opens 25 degrees earlier (160)
- If it fails, it fails in the open position, avoiding an engine overheating condition
Con's
- OEM thermostat opens at 185, so engine must obviously be designed to run at that temp?
- Less heat in the winter
Thank you!
