-=Lobstah=-
So i finally got around tinkering with the RS today. Last update you guys had was that the rear wheels weren't turning. Not so true now, i ended up taking the rear rotors off and the wheels turn just fine now. So the problem was with the e-brake getting stuck or something.
Before i put everything back what should i inspect/replace/check so when everything is back together i wont run into the same problem...
Also what could've caused stuck e-brake?
