Hello Techs.
I have an '04 WRX Wagon with 53k on it. I imagine it's due for some sort of tune up, I'm thinking that I should change the differential fluid as well as the trans gear fluid - but do I need to change the timing belt yet? Most dealerships reccommend changing it at 60k and I'm just wondering if its necessary to do the belt, pully's and water pump.
What is your opinion and knowledge? Is there anything else I should do? When do spark plugs need to be changed? I've had the car for 20k and I've just rotated tires/regular oil changes/air filter.. I just really don't know much abuot cars and that's why I'm here. To hopefully be helped by you wise folks. I've also been told that "Joel" of Evergreen Subaru is a great resource. Can you send me a message if you read this?
Thanks again!!!
-Caitlin
Thanks again!!!
-Caitlin
