Instrument panel lights out :(
-=Lobstah=-
The RS decided to blow a couple of light bulbs a few days ago. 1 is to illuminate fuel and water temp gauges, and another one is for A/C controls. How much of a pain is it to change those and what bulbs to get?
Thanks.
I think all you have to do is pull the cluster out, the bulbs twist out kinda .. they have 2 tabs which slip in the holes, and you turn it so it won't come out ... that's how it was on the leggy one anyway.
What Spin said. Piece-o-cake. The instrument may be bulbs with the socket built in. I only list them like that, but sometimes the bulb pulls out and it is a #194 light bulb. The ones for the heater control are very small push in bulbs. If you are going to a parts store, bring it with you.
Also, the color of the little ceramic part inside the bulb tells you the wattage so make sure its the same as the one you took out. If not, it might be too bright and be annoying.
