That vac solenoid on the manifold looks like it's for the evap canister, or the fuel tank pressure crap.
Follow the hose, I bet it either goes to the charcoal canister, or to the bottom hose under the two fuel hoses on the driver's side.
Only if it goes right to the intake is it iacv.
The ea82 one is actually mounted on the intake manifold. It's a cylinder bolted to a square block that's bolted to the intake manifold.
If it's the same, it's held on with four screws, take it off and clean it out, there isn't much in there. High idle could be caused by a dirty IACV, it did on mine, it was clogged up and couldn't close all the way.
Doubt PCV could cause a high idle, but maybe. It's not a bad idea to replace it anyway, seeing as it's so cheap and easy. Check for vac leaks. Old vacuum hoses are brittal and tend to crack when you start moving them around/exploring.
Also clean your MAF. Use only MAF cleaner, other stuff will ruin it. They can get dirty or even start going bad without throwing a code, but cause idle and run issues.
