Need Help
bigsxy
so today my car decided twice to just shut off when i pushed the clutch in.
I was in the same spot both times at my highschool i was putting the car in first from second and was turning and it died. it started right back up. first time was this morning and the last time was about 30 min ago. when it happened this morning the car had just warmed up and this afternoon it had been running for about 30 min.
i have no idea but hope somebody does
diabloadsit
How strange. I know the 04's had a problem with the clutch switch. But I don't know how that would turn your car off.
Have you gotten into boost? If you did get into boost, did you hear a leak of any sorts?
I know when my BOV was sticking open it would run if just crusining down the road but if I press the clutch to change gears and didn't shift fast enough and give more gas it would die on me. My BOV was stuck open. So massive vac leak for me.
SUBARUDE
what do you have for a fuel pump ferarri has had issue with his walboro fuel pump doing this and i also did when i had spinmasters wrx now it has an stock sti fuel pump and has been fine
