CoupedUpSubie
FWD-FTW
I am currently working on probably the largest school project I have ever undertaken. My plan is to build a wood gas generator and compress the gases into a cylinder of some sort. The cylinder could be used for grills, heaters and with modifications even on a moped. An advantage is that you don't have to burn just wood, any biomass that resembles wood can be used. It is possible to draw the wood gas directly off of the generator and pipe it into a grill, small generator for power outages and even a propane heater in a garage.
My biggest problem right now is getting a compressor set up and putting out the pressures I would like to have. My thought is to use the A/C compressor out of my car, A/C no longer works and I have had plans of pulling it out anyway. Does anyone know what they put out for a pressure or how to "hotwire" it so I can test the pressure. I have test equipment available for me to use if I can get the compressor rotating. I just don't want to drill and pin the clutch if the compressor turns out to be junk anyway.
