ok so the g/f's well-worn Foreter is starting to stink when hot.
turns out the steering rack is leaking where the steering column u-joint enters the rack. seal is weeping, dribbling goop onto exhaust = stinkage
question is, "is this seal repairable, or is it just easier to replace the part with a used one. looks like the rack would have to come out either way.
the leakage is thick milky-white, as if water is mixing with the steering fluid. reservoir level is NOT low, kinda strange. is there maybe some other fluid in this box, not the PSF itself?
O gurus of the Scooby garages with all sorts of experieense fixing old-car weirdness...pls help me.
