STI hybrid w/ stg 2 cams, etc - SS headers - powdercoated intake mani - kevlar timing belt
Evan
I'm selling my complete STI hybrid engine that I never got a chance to put in my WRX. Some parts are brand new, some are used, and I've run none of them
Motor curently has the heads off because I was debating on forged pistons, but I can assemble it if you want.
2.5 STI block (haven't run it but bought it being told it ran fine. 2005 as I recall, bought in like 2009 and sitting in a bag on a stand since)
WRX heads w/ gold/black powdercoated covers
Delta stage 2 cams (,400 lift, 272 duration)
Titainium retainers and springs (brand name coming soon)
EJ257 N/A intake mani (best flowing manifold subaru ever made) powdercoated gold/black
WRX throttle body
Parallele fuel rails w/ braided AN lines/fittings
Modded top feed injectors ("760cc" or whatever)
Gates kevlar timing belt (used, but rated to 300k miles)
New genuine oem oil pump and water pump
Genuine (in the bag) sti head gaskets
Stainless 4 into 1 headers with velocity stack up pipe (I forget the maker, but they're piece as the same as the Maddad and GT spec headers)
wrx engine wire harness/sensors
all engine plastics
probably some other stuff that I'm forgetting.
I'm looking for $2500 for everything complete, and not looking to part out. theres a chance I'll sell some parts separate (headers, intake mani) though.
the last bit is a coworker that has a set of JE forged pistons (stock bore) that he pulled from a block that was supposed to be stock, but it had these in it. He already had his new pistons so he dropped those in, but now he's looking to sell these for $125, without rings. I'll include that for an additional $125 whoever buys the motor wants the deal.
Any interest? I'm in Boston but can come to southern Maine if anyone wants it. I'll be up there saturday 5/17/14 actually.
Here are some pics of the motor as it stands now. The cams/valvetrain isn't in the heads, but I can install them or the new owner could do the shimless-sti conversion (which was my plan originally)
Shown: motor w/ fuel rails, intake, new oem water and fuel pump. below motor are cams, 4-1 headers, wrx wire harness.
closeup of powdercoat job on intake and valve covers. its gold and black hammered finish.
cams are 272 deg and 10mm of lift, or measured at .050" of lift, they're 213deg and .394"
box of kevlar timing belt, belt covers and other accessories
new oem gaskets and such
all the intake mani bolts (and empty bolt holes) are filled with polished stainless cap screws
AN fuel lines and braided hoses
titainium retainers and beehive springs
