Stop being stupid. If you're going to answer about EJ engines get the facts right. EJs only have ONE timing belt unlike the ea82.given the interference engine survived..
if its passenger side I'd be worried...as there is no real problems in heat battles. check cam drag, oil pressure/reliefs/pump
drivers side has several insane heat keepers/thrashers, and a battle of colder than normal freshly cooled anitfreeze from the radiator going into the water pump...driver side will fail sooner.
upon a new one, grease going below -10f is not in any subaru. work in some synthetic to new parts if you can...even if it is a tiny opening, taking awhile.(even hp is increased doing so)
What obs? I didn't think they had the 1.8 after 95 or something. Which was before the switch to phase2/SOHC.I swapped phase2 2.5 into an obs with a 1.8 i dont kno if the 2.2 have the same wiring harness but the 1.8 to 2.5 swap was very easy only slight mods to the wiring harness were needed.
sorry your right its not actually an obs its a impreza outback before the "sport" its a 95What obs? I didn't think they had the 1.8 after 95 or something. Which was before the switch to phase2/SOHC.
I wasn't getting on your case about the wrong name of the car. (me not being an DONKEY on the internet, hmmsorry your right its not actually an obs its a impreza outback before the "sport" its a 95
