ditch_bound
does anyone know what recomended mileage i should change my timing belt on an sti
Plaistow, NH FWIW...some dude in mass i believe. riced out his RS then sold it to radness.
What are the symptoms of a badly stretched t-belt, or more drastically what would they be if the belt is off one tooth?I changed mine on Saturday. The belt looked Ok, but none of the timing marks would line up. That showed me the belt was stretched. When I put the new belt on, they lined up exactly. Now, the car runs and accelerates much more smoothly and doesn't pop on long downhills anymore.
Also, there are some belt guides around 3 of the 4 cams. Did you guys know those are suppose to be set with a feeler guage to 1 mm of clearance? I didn't.
