Tires
Tyler
I need some new tires, and I want to try out rallyX stuff ... What is a good summer tire, fairly cheap, that would run good at an rallyX? What type of tires do better at rallyXs?
Summer tire...rallyX...
Studless snowtires is a better option if you hope to be competitive in even stock class.
Depending on what you've done to your car, you might be in prepared or even modified class. Reading your sig I assume you've done an engine swap, so you'll be up against the other modifed cars. I would recommend at least a good snow tire.
http://xsorbit27.com/users5/subarutunersofmaine/index.php?topic=3571.0
snow or rally tire. I use rally tires when the temps permit, otherwise I use my winter tires, Hakka's, You'll chew up soft compound summers on most of the lots NER uses!
k
You can rally-x with regular tires, I've seen it happen, but you'll have way more speed & fun with something that will dig in for you like snow tires. Dont get gravel tires til you're definately hooked.
Do you need 16s? 15s? We can have Jon at Patriot look in the used pile collection for you. I have 14" snows that you can borrow for some gravel action.
Well my spare wheels are going to be 15s, so I guess if you have some spares, that would be sweet. I need to get some summer tires too, and I'm going to need some this winter too ... blaaaahhh
used Yokohama med compound gravel tires, 205/65-15, $40 each
we got a sheetload of em, they'd be great rallyx tires
Yokos located Camden and/or Bangor, you pick up
I'm going o tempt him with some supah-sexay 15" goldies to run those on
Spin, I have a set of 15" goldies I run for street tires, would make a great set for rally-x
$250 with all-seasons already mounted
Or you can buy my set of 2004 WRX rims with Yokohama all seasons for $250.
:D
Oooh so tempting, but I can't pick those up from you right now. I have a set of alloys from the 94 Leggy I bought, so I'll probably use those for now .. but a second set of goldies would be sweet
I'll let you know about the gravel tires.
