Ok...Heres the thread...I purchased my 2013 STI from a local dealer about 3 weeks ago and didn't notice the issue while test driving. I live in S. Portland and noticed the issue going over the bridge. The car will pull "away" from the corner (turning left car pulls right/straight) while accelerating into the corner, does not matter if turning left or right it happens both ways and if you keep the wheel turned to correct for the pull the second you let off the gas to shift or slow down the car will correct itself and turn towards the way the wheels are turned, which can be pretty drastic if really getting on it and i am still in the break-in period, so haven't really gotten over 4K rpm beside a couple times on accident, so I suspect that hard accel into a corner will cause this to be near uncontrolable...
This phenomenon only happens under acceleration or is only noticable under accel and while turning...I openeded a ticket with the dealer and with SOA... Dealer is trying to get another STI to see if this is a common "charatcerisitc" of the car...
Which from what I can tell it is not and I drove my buddies STI and it did not do it... I have told SOA that if it comes down to it I want the regional rep to drive the vehicle with me to see what is going on and what i am experiencing... The service manager at the dealer openly told me that my STI is the most he has ever driven an STI and he did 6-8 miles, so I don't really have a lot of faith that he would be able to correctly diagnose the issue... He did state that the alignment was dead on and that visually everything looks ok with suspension components...
When I spoke to SOA on Friday they did say that the serv mgr did state that he felt and visually noticed the condition that was happening and that he wasn't sure if it was normal or not...
All the forums I have read have stated that it is either the tires or suspension components or worst case the differential... I have purchased the most accurate digital tire gauge to check tire pressures and they are dead on for factory specs...
I do want to say that my last thread on the suspension issue is unrelated and after driving my STI was definitely just the squishy suspension and bushings on the WRX...
Other than this issue the car is preety much perfect (as pefect as a subaru can be)...
Car... STOCK everything...
Sorry to those people that I pissed off for posting in the shout box.... pretty new to forums and stuff... just read.. . dont really post...
/thanks for any help... Ill update my posts as Subaru figures out this issue for me...
