I use Bridgestone Blizzaks. If you look around and price match with Tire Rack you can ussually get them for the same price as or cheaper than a set of decent studded tires. Cheap studded tires are just that, cheap. They will work on ice, but the will be decent on little else and pop way easier. My oppinion is that if you have AWD then Blizzaks for X-ICE is the way to go, and they can go through more than 1 foot of snow. I know that for a fact because I have done it many times, even on a glare Ice driveway that is slanted. They are like suction cups instead of studs, but that makes them extremely comfortable and quiet in dry conditions, but I see little difference on Ice with studs if the car is AWD. If you have FWD then I would recommend the studs because if only 2 tires are moving, then 2 tires sucking on to the surface won't overcome the drag of the 2 sucking to the surface with out power and they wont dig in and pull, but dry conditions will suck. FWD = Better with studs, AWD = Better without studs. Ice Racing = Studs no matter what, if your going too fast, Blizzaks won't help you. Studs also can damage your fenders when a tire throws a stud. In deep snow on top of Ice with AWD, the Ice won't matter because you wont dig deep enough to hit it, so the studs in that case are a waste, but with FWD, you won't move until you have hit the Ice and dug in, if you cant dig in, then your stuck.
