Trouble with HVAC fan.
Runnah
OK so the the hot/cold works fine just the fan won't go up to 4. 1-3 work fine.
Is this a simple fuse issue or do I have to rip into the dash to replace a switch or fan?
+1 on reostat/resistor or whatever you wanna call it. Same thing was wrong with my RS when i got it.......before the crash.....
30 something greenbacks at Evergreen and 10 mins under the glovebox and you'll be all set
If the resistor goes bad, you loose 1-3 and only 4 works.
The resistor lowers the voltage fed to the fan for the lower speeds. On high, it sends a full 12V. It's not the motor or the resistor. It is probably your switch or the wiring.
lived here 25 years and bought my car last jan. i've never really used 4. my car is usually up to temp in about 10 mins or so. and i end up turning it down cause the car gets too hot.
