WRX and 2.5 SOHC heads and other engine parts
Evan
02 wrx heads complete $300
wrx manifold (bare) $40
wrx oil pump $30
wrx water pump $30
__________
SOHC ej25 heads (99+ forester/legacy, impreza RS, all outbacks?). $225
the passenger side is good, although the drivers side had a valve leaking oil into the cylinder (didnt sound bad though, just smokey) and should probably have valve stem seals replaced at the very least. pulling the valve springs out and checking if the valve slides and rotates freely will tell you if anything else needs to be done.
NEW FROM EVERGREEN:
new SOHC ej25 99+ crank bearings $100 ($160ish EG discount price?)
new SOHC ej25 rod bearings $75 ($120ish EG discount price)
new SOHC ej25 rings (same as other 2.5's?) $75 ($120ish EG discount price)
-=Lobstah=-
If someone is up for an engine build, i have a 2.5 SOHC block with bad crank in it ($25), combined with your parts, would be almost a full engine....
Evan
oh and i have a complete SOHC 2.5 if anyone wants one in running condition. put in new metal headgaskets and timing belt after i pulled it.
