evilaspie- is it a long block or short block? what was the condition of it when you removed it and why did you? and if you could educate me on a external reseal?
I guess long block, that means w/heads right? It's still got the intake manifold, and even power steering + alt i believe, still attached to it.
since it's been sitting for about 2 years and while it's out it wouldn't be a bad idea to replace things like cam seals, valve cover gaskets, rear oil main (i believe it's called), maybe oil pad gasket. Evergreen should be able to supply all the gaskets, etc needed and ship them to you.
I rolled my 98 obs and i stripped the car and kept nearly everything. The engine ran great before the incident.
